For info, found crack at hub in converter! Originally tested with 20# pressure and found nothing. One company rep said that should be enough. Finally took contractor chalk and powdered converter and crack showed immediately. Called company again and rep who sold it to me said pressure test I did probably wasn't enough. They found crack and now deciding what to do! Under warranty! Only 15 runs! Having removed trans SIX times and replacing front pump and seals and bushings hopeful to get fixed.Thanks to all who helped here for input!
