With a dial indicator mounted to the crank and the
indicator on the outer pump bore(no conv or pump in
it) slowly turn the crank and see what you have...
might need to get a set of offset alignment pins...
also check the conv for run out on the input hub...
conv mounted to the crank and indicator mounted to the
block with the indicator on the hub... turn the crank
and see if its out
