Silver70rr(joe) thanks for the heads up about the summit special on the radiator.....
http://store.summitracing.com/default.asp?target=bestdeals.asp
Guys,I need your Opinion on where to mount the Summit radiator, I have 2 sets of holes right now. but because the engine is not in the car I am not sure if I should mount it high or low.
if I mount it high then 2 rows are blocked by the upper core support,
if I mount it low it doesn't look like the ones that you guys showed me this week.
so here are 2 shots with it mounted high and low, what do you think. thanks, Ron...
higher mounted
lower mounted
