Quote: I have the same radiator mounted in the RR similar to how RVA mounted his. Sorry I can't remember the part # for the hose,but I made a simple pattern from a coat hanger and found a hose to fit.
are you runnung a stock fan setup or did you go with an electric one. and how cool/hot does it run on the street. Thanks again, Ron...
Flex fan with a custom shroud...keeps the 451 cool on the street no problem. I have installed a shorter fan spacer since this pic was taken to take better advantage of the shroud.
