If your fuel curve is within what you say you have all the way down the track that is not a symptom of a bad o2 sensor!!! It would have been most likely all over the place. If you had any fuel delivery problem the o2 would have gone dead lean. It dose not mater how many jets are different to other motors in comparison to yours your a/f didnt show that there was a problem. Just saying.
