Dont forget to include a fuel system in that estimate $$$
The fuel system will be the most difficult and the cost will add up quickly. Figure at least $500 to $1000 to get the fuel system right with an in tank pump, baffling, regulator and return line.
The MSD Atomic EFI is the newest of the systems and. Is set up to use an external in line fuel pump without a return line. This will greatly simplify the installation if you meet the requirements for a returnless system (as posted rated in the installation manual posted on the site) . Another benefit is the ability to control timing. There is a special where you get a free MSD 6a box if you buy before the end of May. You can find info at www.atomicEFI.com
The FAST EZ EFI has been around longer has a good reputation and there at guys I. This board running it with good success. They just announced that it now comes with a lifetime warranty.
You can't go wrong with with either System.
Here is a link to a nice comparison chart of the available systems. Although I have been reachering this for a while and iny opinion the only two real options are the MSD Atomic and FAST EZ EFI systems.
https://board.moparts.org/ubbthreads/show...e=2#Post7203253
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
