Re: SB bronze distributor gear- how to install, longevity??
[Re: Moparnut426]
#1232503
05/16/12 07:17 PM
05/16/12 07:17 PM
Posts: 3,427 Toronto
mshred
Toronto
Any lock collar that you can find to keep the gear from climbing up the cam. The collar goes on the distributor. I have a kit from hughes, and they come with detailed instructions. I reused the bronze gear out of my 360 build, It had barely 1000 miles on it by the time my 408 was done. It looked new.
But it wasnt a solid roller it was a hydro roller. Now I have a solid roller with typical solid roller spring pressure on it. I did everything I could to keep the shaft alive. New bushing, collar on the distributor, and used a LOT of molley on the gear prior to fireing it up.
I also used glyptal inside the engine to allow better oil drain back back by the distributor gear. I have seen crud, and chunks of crap back there causing oil not to get into the bushing, so I basically built up the step where the bushing goes into the block with some engine epoxy so the draining back oil can get in to the bushing and not get channeled around it.
Over kill, maybee, but I am not out anything.
If I knew of the milling idea and torrington bearing I would have done that too.
I highly recomend the collar deal your Timing will be ROCK steady. Also a very good timing set helps too.
Thanks for the advice Kasey!
I just checked the Hughes website and can't seem to find this collar you are mentioning? Those are some other really good tips you mentioned as well.
This cam is also a hydraulic roller, not a solid, so hopefully that will help? lol
About the Torrington bearing mod, Thumper, do you have a picture of it? Im not quite able to picture it, unless I am just reading your first posts description wrong?
Entire Thread
mshred
05/13/12 03:28 AM
MR_P_BODY
05/13/12 02:33 PM
mshred
05/13/12 06:22 PM
Thumperdart
05/13/12 06:50 PM
Guitar Jones
05/13/12 06:55 PM
mshred
05/13/12 08:18 PM
mshred
05/13/12 08:17 PM
Thumperdart
05/13/12 09:00 PM
onig
05/14/12 04:30 AM
Guitar Jones
05/14/12 10:37 AM
mshred
05/15/12 01:24 AM
Scamp408
05/15/12 10:00 AM
Guitar Jones
05/15/12 10:56 AM
mshred
05/15/12 09:59 PM
Guitar Jones
05/15/12 10:09 PM
rickraw
05/15/12 10:33 PM
Thumperdart
05/15/12 10:46 PM
mshred
05/16/12 10:58 PM
Moparnut426
05/16/12 11:11 PM
mshred
05/16/12 11:17 PM
Moparnut426
05/16/12 11:19 PM
mshred
05/16/12 11:19 PM
MattW
05/17/12 12:44 AM
TrWaters
05/17/12 02:37 AM
mshred
05/17/12 01:35 PM
Moparnut426
05/17/12 01:45 PM
DusterW2
05/17/12 04:44 PM
DusterW2
05/17/12 11:50 AM
DusterW2
05/17/12 11:51 AM
DusterW2
05/17/12 11:52 AM
70VcodeCoronetRT
05/17/12 01:01 PM
mshred
05/17/12 01:32 PM
Thumperdart
05/17/12 06:17 PM
RAMM
05/17/12 08:14 PM
Thumperdart
05/17/12 08:31 PM
Moparnut426
05/17/12 08:55 PM
Thumperdart
05/17/12 11:43 PM
Moparnut426
05/18/12 03:15 AM
Thumperdart
05/18/12 04:50 AM
mshred
05/17/12 09:14 PM
Thumperdart
05/17/12 12:36 AM
