I have never changed a dist drive gear. The original gear does NOT have a pin in it. So would I have to drill out the shaft to install a pin?
onig
I believe the hardened tip drives have a pin, stock ones do not. There may be exceptions though. These things are tight on that shaft, so I don't know if pinning it is really necessary but I doubt you could drill it anyway it would need to be machined.
This is what I currently have
http://www.summitracing.com/parts/MEL-IS-72
and it looks like this is what I will need?
http://www.summitracing.com/parts/DCC-3690715/?rtype=10
http://www.summitracing.com/parts/MIL-21530/
More unforeseen spending
