I just put strange brakes on the front of my road runner and my prostars fit with no issues?
just to make sure i wasn't shooting my mouth off without cause i went and actually measured things.
the shoulder on the strange hub measures 3.243" and the hole in the weld wheel measures 3.180".
not that it's your case but someone could easily just throw these wheels on these hubs and not notice it but the wheel does NOT seat properly on the hub. i'm gonna hafta put the wheels in the mill and open up the holes.
is it the wheels or the hub's that are wrong? did you check size on another wheel? would it be easier to turn the hub down in the lathe rather than machine the wheel, I would be inclined to find which one is at fault and correct that, might prevent another headache later on.just thinking out loud
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
