The other myth is that stick shifted cars are slower. Is that why pro stock uses them, to be inconsistant and slower?
Could it be their narrow powerbands would not be able to recover fast enough - spending too much time out of their powerband - with only 3 speeds?
It's also hard to put the 40 year old technology of even a modified 833 into a direct comparison to the seamless power application of a planetary shifted modern 5 speed. Apples to oranges.
I think you may be wrong about a "planetary shifted" modern 5-speed... Huh did you get something twisted in the translation.If you mean "planetary transmission" like a Lenco they haven't used one of those for over ten years in Pro-Stock. They use a liberty 5-speed which is "non-planetary" with an inline shifter that could be described as an inline gate shifter that almost works like a ratchet shifter It is a fairly primitive design but it works better than anything else they have available to them at this time. You also don't need to have a Pro-Stock type engine to keep it in the "happy range" My engine likes the gear spread in my 5-speed better than the ratios in an 833 A stick car just lets you be an individual instead of just another one of the sheep following the heard with a glide or a 727 "bomb" Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
