I used the diamond pistons both times. With the 6.535 rod I had to have the counter weights turned to clear the piston. I probably could have gotten away with it fine if I used the longer rod to begin with. The crank is a eagle crank with 440 mains and counter weights. The counter weights were turned down the the standard low deck size.
