say what are you guys using for the trans pan gasket on a 727 ?
buddys car leaked with the rubber gasket and we tried a cork with both side permatex high temp orange sealer and still leaked..
I'd guess you have a leak other than the pan gasket,as either the cork or rubber pan gasket is more than enough to seal.
