You must make sure the pan is flat flat flat....especially around the bolt holes. The trick gasket to use the steel core rubber gasket for a 518 (P2464324). That said I have yet to see a trans pan that leaked because of the gasket. Usually the pan is the culprit.
I wonder if Quaden still has any on the shelf left over from the dealership days?
