you sure the bell crank wasn't to INCREASE leverage? i.e. more pedal travel for less master cylinder stroke? that would be an increase in leverage.
if you had this multiplication of effort before, but removed it and ended up with less leverage, AND went to a manual master, it could be your issue.
can you add the bellcrank back in if it indeed added leverage?
**Photobucket sucks**
