If I am reading this right, you simply changed a master cylinder?
Or did you convert to manual brakes? Because in a manual setup the factory used more leverage than a power setup. If you do not duplicate this extra leverage then you will have a firm pedal with no braking.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
