With the car running put a long 3/4" extension against the alternator, WP and PS pump and have a listen, that should tell you if you have a bearing in one of those components failing. If the nuts holding the shifter tabs loosen off, I tighten them fairly well and loctite them. Make sure you don't tighten the shifter box bolts too tight and bind up the mechanism.
