I took the car out for the first test drive today. It ran perfect! I drove it for about a half hour and it stayed cool the whole time, around 180-185. Oil pressure was good also. No bad noises or leaks. The clutch worked very well, but grabs very high in the pedal travel. I think that's normal for a Centerforce. I seem to remember that in my Vette.
The only issues I have are the shifter (Hurst Comp Plus) and the alternator belt squealing. It took about 2 hours of cursing and swearing to get the stupid shifter to shift smoothly. I thought I had it, then during the drive, I slowly lost the ability to shift to 1st, 3rd and reverse. I'm not sure if the shifter is bad (it's fairly new, but never really worked well) or the linkage is screwed up or what. I have new bushings in there so I know that's not it. I think the rectangular holes in the arms that bolt to the trans are worn and loosen up and move around. All I know is it's infuriating! I want my automatic back! Screw this 4 speed crap!
Also, I have been chasing this nasty alternator belt squeal ever since I got the car. I put new belts on, tightened them properly, used belt dressing, scuffed up the pulley, checked alignment and where the belt rides in the pulley...nothing works. It just squeals like mad above 2500 rpm no matter what I do. The belt dressing quiets it down between 2500-3000rpm for a bit, but then just comes right back after a few minutes. Very annoying. Next step is to replace the alternator.
Also, I really don't like the way the new steering box feels. It's a little vague, especially turning right just off center. And the steering wheel is not centered any more, so I have to adjust the tie rods.
Other than that, all in all, I would say it was a success (so far).
