Quote: DJ... that inner cooler just doesnt look big enough to support 2 good size blowers.. yes I understand the distance that the air will travel....... JMO... looks good though
Looks are deceiving, that is a IC-3000 and has been proven on the dyno already. Same intercooler that was on the video.
Are you running ice in that cooler(pumping cold water through it)... where will the ice chest be
Water/Ice tank will be in the back. Will buy a couple bags in the morning before racing...
Build looks killer man!
Just a heads-up...my slow 10-second hooptie turns 20# worth of intercooler tank ice into bath water on every pass. I think you're going to need more than a couple of bags. I take 150# worth of ice to the track every time I run it in the heat.
