If it is some class racing. Look the rules and go to an event FIRST.
I consider this the most important comment. Figure out who you'll be running with and decide if you want to be competitive. Makes a big difference in prep.
If you run with the SCCA (or a group that uses the rulebook) that Alter-K puts you in CP which is a very high level of prep. 9" wide rims at a minimum with slicks. and then we can start talking corner weights and wheel rates.
1971 Challenger
