I didn't degree it, just installed it dot to dot. It's the cam, lifters, pushrods, and timing set out of my old 360. I figured I should add the engine is in my 78 Fury, with headers, 2.5" duals, A500 trans, and 3.55s. So am I correct in assuming the cam isn't too big, and it should be pulling more vacuum than it is?
If its retarded it will change the vac... is it too big... I dont think so... but you HAVE TO DEGREE it plus I'd advance it 4* so you get better low end torque
You may be able to align the dots in 12 motors and the 13th, or 25th one will bite you. Always take the time to degree them from now on
