A 904 uses a 26 spline and a 727 uses a 29 spline...
weight of the car will make the big difference BUT
you would most likely be better off with the 7290 joint
The car is a '69 Barracuda notchback with fiberglass front end. Guessing 3100 lbs-ish ![](/ubbthreads/images/graemlins/shruggy.gif)
I think I will plan for the 7290 u joints. I will head to the junkyard and get a 904 and 8 3/4 yokes for the 7290. May be hard to get the 8 3/4 yoke off at the junkyard though! I can't get the pinion nut off my 70 Sport Satellite 8 3/4 while its in the car.
