Mines not the fastest, but it's not too bad for what it is....
'78 440 short block
MP .557 cam
906 heads milled to 80cc, std. port, 2.14/1.81 valves
Crane ductile rockers
box stock 750 vac., minus choke plate
I've had three different intakes on it so far, and they all run in the 11.70-75 range, a Torker II, Holley SD and now an M1 single plane.
The car weighs 3,350 with me and has run a best ET of 11.66. My best mph was 115 on an 11.69 pass. This is with 4.10's and a 28" street tire through mufflers.
