looks like i have f- body setup,ok,will that f setup work on the 69 b-body?
yes. But you will need bolts that go through the spindle and lower ball joint.
What did that guy charge you for the F-body disk setup?
What specific parts did that Mopar salvage Yard tell you and sell you for this disk brake swap?
What is the name of that Mopar salvage yard that sold you the parts?
