I hope you are writing about the Charger Lower control arm bushing needing replacement as the Dart LCA will not work. [/quote
I don't know if you guys are aware of this, but an A body lower control arm will bolt up to an B & E body suspension, but the A body LCA is overall "longer" in length, than a B or E body one. Putting an A body LCA into another body style changes the suspension geometry around. But i don't know what adverse effect that it has in doing so. A lot of the roundy, round racers but the A body LCA on the left side of a B body car, as the car would be going in left turns all the time, on a race track setting. On a street driven vehicle, i haven't a clue why someone would want to put in another body stlyes LCA in something that it wasn't intended for.
RF-4C Phantom 69-370 Zweibrucken, Germany
