no i degreed it in at 4* advance. any ideas on low Cranking comp?
Whats the LSA on that cam and did you degree it
when you put it in or did you just use the 4* advanvce
on the gear set.... it sounds like you have it in retarted
Its possible I retarded it but I would feel retarded then.
I used the cam sheet MaMop supplied degreed it straight up and used a 4* button which degreed out at 105 so I left it.
IF i remember right. (that was two winters ago and ive slept since then.)
Put a set of non file fit rings on it but I checked the gap in the bore as calced and required by KB and it was really close so I accepted it.
