Re: Dynomax mufflers VS Flowmasters
[Re: Sunroofcuda]
#1126537
12/28/11 09:01 PM
12/28/11 09:01 PM
Posts: 7,861 Witness Protection Program
Kudakidd
Funny how the little "single" chamber Flowmaster wasn't on that list, just the two and three chambers.
Here's what the single chamber FM looks like on the inside - looks like the exhaust instantly hits a wall upon arrival into the muffler. This causes a huge backlash, which is NOT good. I'd rather run a longer one! We tested 2 & 3 chamber, & Delta Flow FM's when I worked at Dynomax. The 2.5" AND 3" of these series FM's had flow rates of right around 350 sCFM. This translates into 318 loss-free HP with a dual exhaust setup. The Super Turbo 17748 (2.5" x 20" Hemi Super Turbo) has a flow rate of 415 sCFM, which = 378 loss-free HP dual exhaust. A straight-through stainless 2.5" Ultra Flow (#17289 offset/center) has a flow rate of 955 sCFM, which allows 868 loss-free HP on dual exhaust. This is the best flowing 2.5" x 20" oval, offset/center muffler on the market, bar none. The deflector setups inside the Flowmaster mufflers are horrible for flow - they totally kill the flow velocity of the exhaust. Buy them for sound, but not performance.
BTW, a Dynomax 3" x 20" offset/center oval Super Turbo #17769 flows 551 sCFM, which provides 500 loss-free HP on a dual exhaust. A 3" Welded Ultra Flow (20" body, offset/center) #17233 flows 1800 sCFM thus providing 1636 loss-free HP. You can decide from here!
Great write up!
