a few years back, I saw a rear engined dragster that had a big Ford straight 6...I looked closer and here he had Cleveland heads...they had cut the heads and welded them together to make a straight 6 and then machined them...it looked so factory..
you maybe right here that they took two heads to make the one...would that picture be reversed? as far as the slant goes or is that another trick engineering job ...
