What the he!! is that thing?!?
Half a hemi....
Looks more like two of those 4 cylinders welded together with a cylinder removed from each end or one cut in half with the center 2 cylinders from another welded together. It ain't no regular slant 6 that's for sure!
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
