Quote: Very nice like the idea of not cutting frame. How did you move sprngs in.
I used the offset shackle and hangers from Mopar which gain you 3/4". I also had to move the rearend back 5/8" to make room for the height of the 275/60/15. My wheels are 10" with 4 1/2 backspace which probably doesn't help anyone because the housing is custom made to the width that I needed. I made a test housing out of 3" tubing and some mock axle ends to get the width perfect and then gave that to DTS. [image][/image] [image][/image]
