Quote: If the 2" belts in your 15 year old street car failed and you were injured in an accident the manufacturer would be settling with you in a heartbeat so as not to be sued for everything they're worth . This in a car that sits outside in all kinds of weather. I fail to see where a 3" set of belts in a car that is outside only when it is at the track can go bad in only 2 years.
Same thing with a guy that never pulls his car out of a garage in 2 years--your new , never even worn belts are no good.
