Quote: If you use a hydraulic roller camshaft you can use stock stamped steel rockers, just get the pushrod length right. Millions of Detroit hydraulic roller engines have been built with non-adjustable valvetrain.
R.
Really? No change of the big block rockers from stock non adjustable to adjustable? How did you get the dimension for the proper pushrod size, please? How is the streetability? Thanks!
I"m sure it could be done with a checking pushrod and made to order pushrods. The stamped rockers have limits on how much spring pressure they can take. They max out at about .5" lift. I wouldn't see the point in running a roller with such small lift. Might as well run a mild hydraulic flat tappet.
