If you use a hydraulic roller camshaft you can use stock stamped steel rockers, just get the pushrod length right. Millions of Detroit hydraulic roller engines have been built with non-adjustable valvetrain.
R.
Really? No change of the big block rockers from stock non adjustable to adjustable? How did you get the dimension for the proper pushrod size, please? How is the streetability? Thanks!
Persistance is omnipotent
Durability Engineer, Chair and Couch division...
