Quote: One thing not mentioned is that the current MP SS springs will put the shackle at a bad angle (leaning from front to back versus the correct back to front).
2 clarify 4 me should the BOTTOM of the rear vertical shackle b to the rear?
didn't we do this before? yes, pointing towards the bumper. \
Haha! Thanks for clarifying. I re-read what I wrote and I didn't have a clear reference. The shackle eye of the spring should be rearward of the body side of the shackle. My SS springs were just the opposite, which is not good.
If you have the wrong angle at the rear shackle then you have thge wrong springs on the car. That happened when my buddies Dodge has the Plymouth springs on it. Plymouth has a shorter wheelbase. Put the right springs on it and it fixed it. Ron
Let me ax a question, were the XHD springs different between Dodge and Plymouth? I bought a set back in 75 from a junk yard, and don't know what they came out of. I have them under a 71 RR with repo front and rear hangers.
