Not the answer the OP is probably looking for, but at that level of power, 900 ft/lbs, ditch the 727 grenade and move to a PowerGlide or prepped Turbo 400.
At 900 ft/lbs you should be able to accelerate just fine without the added gear reduction.
You don't think a powerglide or a turbo 400 won't blow up ?
Cummins powered rams putting out over 1500 ft/lbs use a 727 based OD trans and don't blow up when built properly .
My 3000 pound Outlaw car makes twice that much torque and our Mike's glide has never broken.
I left out these 1500# Cummins trucks are 4x4's that weigh in at 7000lbs.
A 727 isn't right for every application but it will handle 900#, most people go to the GM based trans more because of cost than anything else .
