Quote: Thanks,Gary! Guess it'll stay in the top hole...don't need it any higher! I use the 9-way Rancho rear shock...has anyone had a problem with them not having enough travel...and bottoming out?
Be sure to check them as their are couple of different shocks, extended length should be around 25 to 25 1/2" long, if not the shocks may top out when you launch the car
