You might also want to add a shock extension to give you a little more travel in the shocks so they are not limiting any travel. Hard to get it set up right if the shocks are fully extended and limiting what the springs are trying to do. You may find you need to lower the front bolt hole down 1 hole to settle it out a litle. Go with the shortest set of shackles you can get away with.
