Quote: Hello Mike, I can't believe it but I drained the radiator and added plain hose water.
now drain it all and replace it with anti-freeze and distilled water.
i know some people argue this point, but every radiator guy i know insists on it, as well as all the engine builders i can think of. the minerals in tap water will eventually cause build-up and corrosion.
