White wire at 7 has fire when brakes are pressed. 3 & 6 at rear harness have fire when brakes are pressed. (That's why I'm confused - if 3 & 6 have 12V+ the darn lights should work).
Even though 7 has 12V when brakes are pressed, jumpering 7 (white wire) directly to 3 or 6 does not light the lights. Jumpering directly from the battery to 3 or 6 does light them.
that's 3/6 in the forward half of the rear harness connector behind the kick panel that does have fire when pedal pressed but you connect the halves & no br lites as in no continuity from the connector to the rear when you connect them? but from the batt directly to 3/6 in the rear half of the kick panel connector you're good? And w the kick panel connector connected and jumping fire upstream from there to the white wire at the rear half of the dangling TS connector no brake lites?
