valve spring compressor #997581
05/22/11 04:38 PM
05/22/11 04:38 PM
PA
BTTG Offline OP
BTTG  Offline OP
PA
will i be able to get my comp cam 911 spring on my 906 heads with this?
http://www.summitracing.com/parts/PRO-66832/
had a 60$ one from advance auto and it was bending wildly (total POS)
Re: valve spring compressor [Re: BTTG] #997582
05/22/11 04:54 PM
05/22/11 04:54 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
I have a HD KD brand ... never had a prob with that.
Re: valve spring compressor [Re: BTTG] #997583
05/22/11 05:08 PM
05/22/11 05:08 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That one will work, barely. It's a POS also.
Re: valve spring compressor [Re: BTTG] #997584
05/22/11 10:56 PM
05/22/11 10:56 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have one of those and it worked fine on my PAC-1325 springs (over 700# compressed.)
I wish the cam lever on it was drilled overcenter so it would hold the spring compressed, but on mine you still have to apply some pressure to maintain the compressed position. From what I have seen it is pretty good for the price. When I was looking for one, the next step better one was over twice the price.
Re: valve spring compressor [Re: BTTG] #997585
05/22/11 11:57 PM
05/22/11 11:57 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
$95 for a POS ... ouch !!! I have an amazing one that I picked up at an auction for $25.. Check around for a used one - maybe on Craigslist or something like that. For the short time you need it, how about a tool rental place ???
Re: valve spring compressor [Re: BTTG] #997586
05/23/11 12:32 AM
05/23/11 12:32 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
This is the best one ever. It is designed to be used on the engine, but if you clamp the head to the table it works great. I JUST used it 3 minutes ago to check piston to valve clearance with my current cam so I can see what size roller I can go to.
Comp Cams 5324
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: valve spring compressor [Re: BTTG] #997587
05/23/11 02:48 PM
05/23/11 02:48 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Built this for under $20 works fantastic!!
Re: valve spring compressor [Re: R/T1968R/T] #997588
05/23/11 02:49 PM
05/23/11 02:49 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
The "T" fitting needs to have the threads removed and polished
Re: valve spring compressor [Re: 451Mopar] #997589
05/23/11 02:57 PM
05/23/11 02:57 PM
Cincinnati, Ohio
Cincinnati, Ohio
IMO it's a wobby POS made in china, How are you supposed to assemble the keepers if you can't let go of it?
Buy one with a fixed frame, NOT a wobby adjustable one.
Re: valve spring compressor [Re: R/T1968R/T] #997590
05/24/11 08:31 AM
05/24/11 08:31 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
you can also modify a stamped steel rocker arm by adding some arms to push against the retainer and put a lever arm on it and it will work similar to the pipe t. i don't have a pic but that's how i made 1. i also cut an extra shaft i had so it only bridged 2 stands.
