valve spring compressor
#997581
05/22/11 04:38 PM
05/22/11 04:38 PM
Posts: 582 PA
BTTG
PA
will i be able to get my comp cam 911 spring on my 906 heads with this? http://www.summitracing.com/parts/PRO-66832/had a 60$ one from advance auto and it was bending wildly (total POS)
Re: valve spring compressor
[Re: BTTG]
#997586
05/23/11 12:32 AM
05/23/11 12:32 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
This is the best one ever. It is designed to be used on the engine, but if you clamp the head to the table it works great. I JUST used it 3 minutes ago to check piston to valve clearance with my current cam so I can see what size roller I can go to. Comp Cams 5324
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 451Mopar]
#997589
05/23/11 02:57 PM
05/23/11 02:57 PM
Challenger 1
Cincinnati, Ohio
I have one of those and it worked fine on my PAC-1325 springs (over 700# compressed.) I wish the cam lever on it was drilled overcenter so it would hold the spring compressed, but on mine you still have to apply some pressure to maintain the compressed position. From what I have seen it is pretty good for the price. When I was looking for one, the next step better one was over twice the price.
IMO it's a wobby POS made in china, How are you supposed to assemble the keepers if you can't let go of it?
Buy one with a fixed frame, NOT a wobby adjustable one.
