OK.............Let's see a show of hands. #997536
05/22/11 03:48 PM
05/22/11 03:48 PM
On the south side of Nowhere
S/ST 3040 Offline OP
How many of you HATE gapping rings?
That's me with both hands up.
Re: OK.............Let's see a show of hands. [Re: S/ST 3040] #997537
05/22/11 03:49 PM
05/22/11 03:49 PM
4 more holes left.
Re: OK.............Let's see a show of hands. [Re: S/ST 3040] #997538
05/22/11 03:51 PM
05/22/11 03:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Re: OK.............Let's see a show of hands. [Re: S/ST 3040] #997539
05/22/11 03:52 PM
05/22/11 03:52 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Never thought about doing it with a TQ plate installed, very good idea
Re: OK.............Let's see a show of hands. [Re: HotRodDave] #997540
05/22/11 04:06 PM
05/22/11 04:06 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
just thought the same!
i truly hate it,especialy oilrings
Re: OK.............Let's see a show of hands. [Re: S/ST 3040] #997541
05/22/11 04:15 PM
05/22/11 04:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I actually like it cos I at least know it`s done right and plus it`s part of the "blue printing" process which give me a chance to pound some beers and rock out to some hard rock.
Re: OK.............Let's see a show of hands. [Re: Thumperdart] #997542
05/22/11 04:18 PM
05/22/11 04:18 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I dont mind it. But, my hands really hurt by hole 6 or so.
As far as using a plate, most ring mfgs say to gap with a plate installed. Ive never done it, but I happened to have a borrowed plate on hand last time, so I did it.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: OK.............Let's see a show of hands. [Re: Von] #997543
05/22/11 04:32 PM
05/22/11 04:32 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Pretty tedious, as I'm a perfectionist.
Re: OK.............Let's see a show of hands. [Re: S/ST 3040] #997544
05/22/11 05:34 PM
05/22/11 05:34 PM
Az
Crizila Offline
Crizila  Offline
Az
4 more holes left.
My ring squaring tool does not allow me to use a torque plate. Not sure how critical that is the torque plate I mean. Getting the ring square on the grinder and in the hole IS critical.
Fastest 300
Re: OK.............Let's see a show of hands. [Re: Crizila] #997545
05/22/11 07:33 PM
05/22/11 07:33 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
The side of the stone on the bench grinder works pretty good. Take some practice to make them square, but if you get the hang of it the process goes so fast you can get to the really fun part, checking bearing clearances...
Re: OK.............Let's see a show of hands. [Re: S/ST 3040] #997546
05/22/11 07:46 PM
05/22/11 07:46 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
You need to buy an electric ring filer,........so I can borrow it!
Keith
Re: OK.............Let's see a show of hands. [Re: Dunnuck Racing] #997547
05/22/11 08:09 PM
05/22/11 08:09 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I use a ring filer with the crank handle, after 2 holes you can count the turns and be right on, and course there's the finish burr clean up. I would rather file rings than install spiro locks
Re: OK.............Let's see a show of hands. [Re: rowin4] #997548
05/22/11 08:49 PM
05/22/11 08:49 PM
Az
Crizila Offline
Crizila  Offline
Az
For sure I use a honing stone to knock off any sharp edges left from my ring filer. It's time consuming using the stone after each filing, but as said, you can hone in on the number of cranks and get pretty close after a few 's
Fastest 300
Re: OK.............Let's see a show of hands. [Re: rowin4] #997549
05/22/11 09:58 PM
05/22/11 09:58 PM
NC
440Jim Offline
440Jim  Offline
NC
That is what I do. I don't think too much about it. But I am very detail oriented and take way too much time doing all sorts of things.
I have a diamond jewlers file to help make the final gap exactly parallel for that last 0.001"
Re: OK.............Let's see a show of hands. [Re: S/ST 3040] #997550
05/22/11 10:06 PM
05/22/11 10:06 PM
tn
robnbird Offline
robnbird  Offline
tn
Ya I know what you mean. I just stopped using them.
Re: OK.............Let's see a show of hands. [Re: robnbird] #997551
05/22/11 10:12 PM
05/22/11 10:12 PM
Saline, MI
E
efisixpack Offline
efisixpack  Offline
E
Saline, MI
I'm going to be putting together my 440 short block in a few weeks and was wondering who has the best tool for grinding ring? Also, what is the best way to debur rings? Jewlers file like stated above or what else to use? Thanks in advance, I'm a little rusty in this department and just trying to freshen up on my tools/skills.
When I die I want to go like my Grandfather did, quietly in his sleep. Not screaming like the passengers in his car.
Re: OK.............Let's see a show of hands. [Re: robnbird] #997552
05/22/11 10:16 PM
05/22/11 10:16 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Re: OK.............Let's see a show of hands. [Re: rowin4] #997553
05/22/11 10:22 PM
05/22/11 10:22 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I bought one of those crank ring filers from Summit. I sent it back, Way to slow.
I opted for my much more productive Sears belt/disc sander. Turns out it was a little to Productive. the first time I used it.
I over cut a ring on a cylinder and ended up buying a whole another set of Rings. At the time I couldnt buy just one. I got a whole lot of spares now.
But Ive got the disc sander technigue down now, and it is the method I prefer. I can buzz up a set in 5 minutes, Just kidding.
Re: OK.............Let's see a show of hands. [Re: Sport440] #997554
05/22/11 11:03 PM
05/22/11 11:03 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
Just went through the whole shortblock assembly this weekend-bearing clearance,spiral locks,ring filing,cam degree,final deck height check.
As far as the ring filing, I found that I never put the same amount of tension on each as I filed so I just used a base number of strokes for each ring, top(15) and second(10), then adjusted from there. Having the filer next to the block-major time saver, but still didn't help my back out much.
This little device would sure be a nice addition to the garage.
http://www.youtube.com/watch?v=RHSoSZvHoCo
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: OK.............Let's see a show of hands. [Re: S/ST 3040] #997555
05/23/11 03:38 AM
05/23/11 03:38 AM
Cab_Burge Online work
Cab_Burge  Online Work
4 more holes left.
Do you use the torque plate on your heads when doing the valve job If not try it It is amazing what you can find that makes a difference in results on H.P. motors, especially when your competion is outrunning you
