Re: OK.............Let's see a show of hands.
[Re: HotRodDave]
#997540
05/22/11 04:06 PM
05/22/11 04:06 PM
Posts: 2,578 sweden
1Fast340
sweden
Never thought about doing it with a TQ plate installed, very good idea
just thought the same!
i truly hate it,especialy oilrings
[Re: Thumperdart]
#997542
05/22/11 04:18 PM
05/22/11 04:18 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I dont mind it. But, my hands really hurt by hole 6 or so.
As far as using a plate, most ring mfgs say to gap with a plate installed. Ive never done it, but I happened to have a borrowed plate on hand last time, so I did it.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: rowin4]
#997549
05/22/11 09:58 PM
05/22/11 09:58 PM
Posts: 16,928 NC
440Jim
NC
I use a ring filer with the crank handle, after 2 holes you can count the turns and be right on, and course there's the finish burr clean up. I would rather file rings than install spiro locks
That is what I do. I don't think too much about it. But I am very detail oriented and take way too much time doing all sorts of things. I have a diamond jewlers file to help make the final gap exactly parallel for that last 0.001"
[Re: S/ST 3040]
#997550
05/22/11 10:06 PM
05/22/11 10:06 PM
Posts: 914 tn
robnbird
tn
[Re: robnbird]
#997551
05/22/11 10:12 PM
05/22/11 10:12 PM
Posts: 1,240 Saline, MI
efisixpack
Saline, MI
I'm going to be putting together my 440 short block in a few weeks and was wondering who has the best tool for grinding ring? Also, what is the best way to debur rings? Jewlers file like stated above or what else to use? Thanks in advance, I'm a little rusty in this department and just trying to freshen up on my tools/skills.
When I die I want to go like my Grandfather did, quietly in his sleep. Not screaming like the passengers in his car.
[Re: rowin4]
#997553
05/22/11 10:22 PM
05/22/11 10:22 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I bought one of those crank ring filers from Summit. I sent it back, Way to slow.
I opted for my much more productive Sears belt/disc sander. Turns out it was a little to Productive. the first time I used it.
I over cut a ring on a cylinder and ended up buying a whole another set of Rings. At the time I couldnt buy just one. I got a whole lot of spares now.
But Ive got the disc sander technigue down now, and it is the method I prefer. I can buzz up a set in 5 minutes, Just kidding.
[Re: Sport440]
#997554
05/22/11 11:03 PM
05/22/11 11:03 PM
Posts: 553 Kentucky
clovis
Kentucky
Just went through the whole shortblock assembly this weekend-bearing clearance,spiral locks,ring filing,cam degree,final deck height check. As far as the ring filing, I found that I never put the same amount of tension on each as I filed so I just used a base number of strokes for each ring, top(15) and second(10), then adjusted from there. Having the filer next to the block-major time saver, but still didn't help my back out much. This little device would sure be a nice addition to the garage. http://www.youtube.com/watch?v=RHSoSZvHoCo
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
