Engine/Cam noise #995894
05/19/11 10:39 PM
05/19/11 10:39 PM
MS, USA
K
killercoronet Offline OP
K
MS, USA
I got a little noise coming from my 440. Its a new build, less than 100 miles on it. Its not a "knock" its just just like a little tick sort of. Im wondering if its just engine noise from the solid lift cam. Its a comp 280H. The motor was assembled by a very reputable builder in town, but im nervous about driving it till I know for sure. Any thoughts?
Re: Solid lift cam noise [Re: killercoronet] #995895
05/19/11 10:44 PM
05/19/11 10:44 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
have you checked the valve lash?
Re: Solid lift cam noise [Re: DJVCuda] #995896
05/19/11 10:45 PM
05/19/11 10:45 PM
MS, USA
K
K
MS, USA
not yet, i've thought about that. Anybody know the specs for that. I got mopar adjustable rockers solid tip.
Re: Solid lift cam noise [Re: killercoronet] #995897
05/19/11 10:48 PM
05/19/11 10:48 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
your cam card will have the required lash settings.
Re: Solid lift cam noise [Re: killercoronet] #995898
05/19/11 10:53 PM
05/19/11 10:53 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
280H? Doesn't the H denote a hydraulic rather than solid cam?
Engine/ cam noise [Re: G_bob] #995899
05/19/11 10:56 PM
05/19/11 10:56 PM
MS, USA
K
K
MS, USA
haha yeah your right it does, my bad!
Re: Engine/ cam noise [Re: killercoronet] #995900
05/19/11 10:57 PM
05/19/11 10:57 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
good catch!
Re: Engine/Cam noise *DELETED* [Re: killercoronet] #995901
05/20/11 04:13 AM
05/20/11 04:13 AM
minnarusta
TX9H6E4CUDA Offline
TX9H6E4CUDA  Offline
minnarusta
Post deleted by killercoronet
Great job
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Engine/Cam noise *DELETED* [Re: TX9H6E4CUDA] #995902
05/20/11 05:16 AM
05/20/11 05:16 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Killer, what kind of pistons were used in your build? If forged, you may just be hearing some piston noise from clearances required for some forged slugs. Does it get quieter once warmed up?
Re: Engine/Cam noise [Re: killercoronet] #995903
05/20/11 08:32 AM
05/20/11 08:32 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Not anymore.
Earning every penny of that moderator paycheck.
DBAP
Re: Engine/Cam noise [Re: not_a_charger] #995904
05/20/11 11:03 AM
05/20/11 11:03 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
nice save!!
now we can all learn from the original question!
DO NOT DELETE YOUR QUESTIONS!!!
ticking noise...anything really... piston knock till they warm up and tighten up on their specs, which is why we let them fully warm up before beating on them.
could be an exhaust leak that developed, as headers are notorious for burning out gaskets nad ticking/leaking
could just be the sound of the cam. my hydraulic cam worried me at first too, being that it's my first performance build...sounds like a darn sewing machine tapping away.
pull the valve covers, check that you didn't have an adjustable rocker back off, I've had that happen to me too, even with a hydraulic cam, that'll make a tick. then check your header bolts to make sure there's no leaks. start it up and hold your hand around the headers before they get hot to feel for exhaust puffing past the gasket...if all checks well, then it's probably just normal...let it fully warm up before beating on it.
**Photobucket sucks**
Re: Engine/Cam noise [Re: 70Cuda383] #995905
05/20/11 02:27 PM
05/20/11 02:27 PM
MS, USA
K
K
MS, USA
They're stock pistons. It was a very low mileage motor, we just went in and honed the cylinders new rings etc. And the sewing machine example is pretty accurate. Its not exhaust leak either i checked that. And it does quieten down after it warms up. It doesn't sound horrible it just caught my attention and thought I'd see what ya'll thought. Sorry for attempting to deleting the post to.
Re: Engine/Cam noise [Re: killercoronet] #995906
05/20/11 05:24 PM
05/20/11 05:24 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
For your peace of mine, best bet is to follow the advice above. Pull the valve covers and double check the valve adjustment. Make sure they all have the appropriate amount of preload (zero lash plus a half to 3/4 turn on the adjuster).
Good luck.
Re: Engine/Cam noise [Re: 70Cuda383] #995907
05/20/11 10:00 PM
05/20/11 10:00 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
...not wanting to hi jack the post '70 cuda, but what cam did you install?
Re: Engine/Cam noise [Re: killercoronet] #995908
05/21/11 06:50 PM
05/21/11 06:50 PM
MS, USA
K
K
MS, USA
Took the valve cover off today, easy fix. The rocker arm was barely hitting the baffle in the cover.I took a hammer and dented it in a little bit and it cleared right up.
