Engine/Cam noise
#995894
05/19/11 10:39 PM
05/19/11 10:39 PM
Posts: 238 MS, USA
killercoronet
MS, USA
I got a little noise coming from my 440. Its a new build, less than 100 miles on it. Its not a "knock" its just just like a little tick sort of. Im wondering if its just engine noise from the solid lift cam. Its a comp 280H. The motor was assembled by a very reputable builder in town, but im nervous about driving it till I know for sure. Any thoughts?
Re: Solid lift cam noise
[Re: killercoronet]
#995898
05/19/11 10:53 PM
05/19/11 10:53 PM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
280H? Doesn't the H denote a hydraulic rather than solid cam?
Re: Engine/Cam noise
[Re: not_a_charger]
#995904
05/20/11 11:03 AM
05/20/11 11:03 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
nice save!! now we can all learn from the original question! DO NOT DELETE YOUR QUESTIONS!!! ticking noise...anything really... piston knock till they warm up and tighten up on their specs, which is why we let them fully warm up before beating on them. could be an exhaust leak that developed, as headers are notorious for burning out gaskets nad ticking/leaking could just be the sound of the cam. my hydraulic cam worried me at first too, being that it's my first performance build...sounds like a darn sewing machine tapping away. pull the valve covers, check that you didn't have an adjustable rocker back off, I've had that happen to me too, even with a hydraulic cam, that'll make a tick. then check your header bolts to make sure there's no leaks. start it up and hold your hand around the headers before they get hot to feel for exhaust puffing past the gasket...if all checks well, then it's probably just normal...let it fully warm up before beating on it.
**Photobucket sucks**
[Re: killercoronet]
#995906
05/20/11 05:24 PM
05/20/11 05:24 PM
G_bob
Riverside, Ca
They're stock pistons. It was a very low mileage motor, we just went in and honed the cylinders new rings etc. And the sewing machine example is pretty accurate. Its not exhaust leak either i checked that. And it does quieten down after it warms up. It doesn't sound horrible it just caught my attention and thought I'd see what ya'll thought. Sorry for attempting to deleting the post to.
For your peace of mine, best bet is to follow the advice above. Pull the valve covers and double check the valve adjustment. Make sure they all have the appropriate amount of preload (zero lash plus a half to 3/4 turn on the adjuster). Good luck.
