Warped trans steels, what caused this ? UPDATE PICS #995553
05/19/11 12:41 PM
05/19/11 12:41 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
94 Ram 1500 4x4 w/360 engine, 213,000 miles, burnt fluid and wouldn't go. Taking this apart and found the steels warped & burnt, clutches actually don't look bad. I'm replacing the convertor along with rebuild is there anything else I should look for for the cause. Obviously overheated, but what could have caused it? Thanks for any help.
Re: Warped trans steels, what caused this ????? PICS [Re: 340Scamp] #995554
05/19/11 12:46 PM
05/19/11 12:46 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Slipping clutch, the clutches don't look bad??? The clutches not holding caused those steels to warp like that. Clutches are GARBAGE , use the Hi energy clutches as a replacement if you haven't already bought the rebuild kit.
edit ... looking at the picture I see the rear clutch stack in the back ground , that's the front clutch , this was probably caused by the front drum having the inner piston seal cut too deep , there is a wider replacement seal to remedy this , it comes in the seal kit , if it doesn't specifically get one and use it.
Re: Warped trans steels, what caused this ????? PICS [Re: 340Scamp] #995555
05/19/11 12:46 PM
05/19/11 12:46 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
another pic
Re: Warped trans steels, what caused this ????? PICS [Re: 340Scamp] #995556
05/19/11 12:51 PM
05/19/11 12:51 PM
U.S.S.A.
U.S.S.A.
As long as the thick plate is not warped also you can just flip it over and you'll have a fresh surface , otherwise replace it. do the same wit hthe rear clutch , flip over the thick plate but replace the inner plate and the scalloped spring plate (bellville sp??) under it.
Re: Warped trans steels, what caused this ????? PICS [Re: JohnRR] #995557
05/19/11 01:44 PM
05/19/11 01:44 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
Correct John, it's the front clutch. I appreciate the help.
Re: Warped trans steels, what caused this ????? PICS [Re: 340Scamp] #995558
05/19/11 02:10 PM
05/19/11 02:10 PM
U.S.S.A.
U.S.S.A.
Before this happened did you notice a delayed 2-3 shift wit han RPM flare or the reverse engaging harshly ?
Re: Warped trans steels, what caused this ????? PICS [Re: JohnRR] #995559
05/19/11 02:54 PM
05/19/11 02:54 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
I bought the truck with the trans already bad. I think I found the problem. The output shaft is seized at the sprag. Took tailshaft off and the output shaft will not move by hand. Had to put channel locks on it to turn it and still is extremely tight. Also can't get the rear drum off, band is loose but drum won't come off.
Re: Warped trans steels, what caused this ????? PICS [Re: 340Scamp] #995560
05/19/11 07:08 PM
05/19/11 07:08 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
Shaft was seized to the support. Had to cut it off, time to order more parts.
Re: Warped trans steels, what caused this ????? PICS [Re: 340Scamp] #995561
05/19/11 07:10 PM
05/19/11 07:10 PM
U.S.S.A.
U.S.S.A.
The lube circuit is plugged up the rear support is lubed by the fluid that runs into it from the rear line, when that clogs that is what happens . There is a modified rear support made by Sonnax that has modified lube paths for the mainshaft and the drum, you are going to have to force the thing apart and replace the mainshaft, the support and the rear drum.
Sonnax has 2 supports, one upgrade part # 22754N-01K and one with a larger OOD on the surface that the drum rides on so you and bore out the ID of the drum because they are expensive to replace, part # 22754N-02K
Re: Warped trans steels, what caused this ????? PICS [Re: JohnRR] #995562
05/19/11 09:36 PM
05/19/11 09:36 PM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
you had better repair the check ball in the trans line up by the radiator or you will tear up the support again as the lube circuit to the support and intermediate shaft gets cut off by a stuck check ball in the line also check for good cooler flow..better yet remove the check ball and put a full time lube kit in the valve body
70 cuda 440 6bbl Auto with a dana 60
68 road runner QQ1 383 auto
1970 6 barrel 4 speed Superbird FY1 number matching
15 Challenger 6.4 SRT pearl White 6 Speed
72 Cuda 440 5 speed
71 Road Runner 440 4 speed
Re: Warped trans steels, what caused this ????? PICS [Re: jwilson 61] #995563
05/20/11 11:40 AM
05/20/11 11:40 AM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
Thanks everyone, here's another pic of the damage to the support & sprag roller basket.
Re: Warped trans steels, what caused this ????? PICS [Re: jwilson 61] #995564
05/20/11 12:16 PM
05/20/11 12:16 PM
U.S.S.A.
U.S.S.A.
Good point , if the converter wasn't the source of the trash that clogged the cooler circuit it's possible that the rubber line with the check ball failed .
Re: Warped trans steels, what caused this ????? PICS [Re: JohnRR] #995565
05/20/11 09:05 PM
05/20/11 09:05 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
Where in the line is the check ball located? I traced the lines from the trans to the radiator and can't seem to find it. Also what does it look like? The only thing I found was a temp censor in the line next to the trans.
Re: Warped trans steels, what caused this ????? PICS [Re: 340Scamp] #995566
05/20/11 09:17 PM
05/20/11 09:17 PM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
usually found right where the lines turn from steel to rubber before the radiator cooler its part of the connector right at the steel line. it disconnects right there and you can see the check ball inside the connector. the full time lube really helps vehicles with remote starters keep from burning up front pump bushings and associated parts
72 Cuda 440 5 speed
Re: Warped trans steels, what caused this ????? PICS [Re: jwilson 61] #995567
05/20/11 09:49 PM
05/20/11 09:49 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
The output shaft seized up in my old dakota just like that , melted sprag cage and all. The factory check ball in the cooler line was plastic!!!
There,s an aftermarket fitting aviabile with a stainless steel check ball but the better fix is mentioned above .
Make sure you thoughly flush the trans cooler/s or even consider replacing the whole radiator.
Good luck on finding some resoneably priced hard parts and or a rebuildable core.
Re: Warped trans steels, what caused this ????? PICS [Re: ChinooK440] #995568
05/21/11 11:25 AM
05/21/11 11:25 AM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
What's the purpose of the check ball? Will taking it out create any future problems? Can I flush the system with compressed air, around 35 lbs. pressure?
Re: Warped trans steels, what caused this ????? PICS [Re: 340Scamp] #995569
05/21/11 12:56 PM
05/21/11 12:56 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
I believe it's there to keep the converter from draining while sitting. Taking it out may be mean a slight delay when you first shift out of park in the morning.
Re: Warped trans steels, what caused this ????? PICS [Re: 340Scamp] #995570
05/21/11 03:39 PM
05/21/11 03:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Below is a pic of the check valve line; top is factory original, bottom is replacement.
The factory installed the check valve to prevent the cooler from draining back into the transmission through the converter. In older days the cooler was mounted in the bottom radiator tank near the level of the transmission but the newer crossflow radiators with side tanks place the cooler above the level of the transmission.
Removing the check valve might require placing the shifter in Neutral for the first start of the day.
Re: Warped trans steels, what caused this ????? PICS [Re: John_Kunkel] #995571
05/21/11 04:17 PM
05/21/11 04:17 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Hmm, this may explain my wife's 05 Ram's trans. Take it a bit to get going when you put it in gear. Bet the check valve is stuck open letting the converter drain back. So, where does one get the "good" check valve?
Don't be the exception.
Re: Warped trans steels, what caused this ????? PICS [Re: Supercuda] #995572
05/22/11 02:45 AM
05/22/11 02:45 AM
U.S.S.A.
U.S.S.A.
Probably not the check ball sticking , later rams seems to have the drainback issue as delivered from the factory , tell her to start it , pop it into neutral and wait a minute , should be all set to go .
