Sealant around engine block coolant neck? #995508
05/19/11 11:14 AM
05/19/11 11:14 AM
Albany, NY
67SATisfaction Offline OP
The member whose name is actually Art
Albany, NY
I've got some pitting on the coolant neck at the top of my engine block, and I want to avoid seeping coolant on my brand-new restoration.
Has anyone used sealant that works well other than RTV silicone? I don't want it to be totally stuck on if I have to replace it sometime, so I was thinking of the non-hardening intake manifold sealant.
Any recommendations are appreciated.
Thanks,
-Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Sealant around engine block coolant neck? [Re: 67SATisfaction] #995509
05/19/11 11:23 AM
05/19/11 11:23 AM
In a town not near you.
clownzilla Offline
clownzilla  Offline
I had the same problem on the top of my intake and nothing I tried would seal it from seeping until I took a flat sharpening wet stone to the top of the intake to file down the pitting, then I used the red high temp RTV sealant at the bottom of the T stat housing gasket and have not seeped a drop since.
I use a billet steel housing, never chrome.
Some guys may have better solutions but that's what worked for me.
The early bird gets the worm, and the second mouse always gets the cheese.
Re: Sealant around engine block coolant neck? [Re: clownzilla] #995510
05/19/11 12:07 PM
05/19/11 12:07 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Permatex brown.I use it all the time.It dosent hard and stops any minor leaks.Rocky
Chrysler Firepower
Re: Sealant around engine block coolant neck? [Re: therocks] #995511
05/19/11 01:28 PM
05/19/11 01:28 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Re: Sealant around engine block coolant neck? [Re: 67SATisfaction] #995512
05/19/11 04:21 PM
05/19/11 04:21 PM
Permatex #3 brush on, on a gasket
Re: Sealant around engine block coolant neck? [Re: RapidRobert] #995513
05/19/11 11:44 PM
05/19/11 11:44 PM
Albany, NY
Albany, NY
Thanks gentlemen!
- Art
Re: Sealant around engine block coolant neck? [Re: 67SATisfaction] #995514
05/19/11 11:54 PM
05/19/11 11:54 PM
IN
ahy Offline
ahy  Offline
IN
File and smooth as best possible and Permatex #1 (brown). It seems to work much better than RTV in this app.
Re: Sealant around engine block coolant neck? [Re: ahy] #995515
05/20/11 12:34 AM
05/20/11 12:34 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
What ahy sez: gotta have flush smooth surfaces, then the Permatex. I like anti-sieze or bolt-prep on the bolt threads, too. And test your thermostat in some boiling water with a thermometer before installing it.
Re: Sealant around engine block coolant neck? [Re: Ronnman] #995516
05/20/11 01:09 AM
05/20/11 01:09 AM
Spokane Valley WA
dan6412 Offline
dan6412  Offline
Spokane Valley WA
Permatex Hylomar
http://www.amazon.com/Permatex-85249-Hylomar-Universal-Dressing/dp/B0018PSATY
I usee it alot on my engines. Works great on valve covers too. Never gets hard
Re: Sealant around engine block coolant neck? [Re: topside] #995517
05/20/11 04:30 PM
05/20/11 04:30 PM
X 2
