Sealant around engine block coolant neck?
#995508
05/19/11 11:14 AM
05/19/11 11:14 AM
Posts: 7,541 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I've got some pitting on the coolant neck at the top of my engine block, and I want to avoid seeping coolant on my brand-new restoration. Has anyone used sealant that works well other than RTV silicone? I don't want it to be totally stuck on if I have to replace it sometime, so I was thinking of the non-hardening intake manifold sealant. Any recommendations are appreciated. Thanks, -Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Sealant around engine block coolant neck?
[Re: 67SATisfaction]
#995509
05/19/11 11:23 AM
05/19/11 11:23 AM
Posts: 5,281 In a town not near you.
clownzilla
I had the same problem on the top of my intake and nothing I tried would seal it from seeping until I took a flat sharpening wet stone to the top of the intake to file down the pitting, then I used the red high temp RTV sealant at the bottom of the T stat housing gasket and have not seeped a drop since. I use a billet steel housing, never chrome.
Some guys may have better solutions but that's what worked for me.
The early bird gets the worm, and the second mouse always gets the cheese.
[Re: clownzilla]
#995510
05/19/11 12:07 PM
05/19/11 12:07 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Permatex brown.I use it all the time.It dosent hard and stops any minor leaks.Rocky
Chrysler Firepower
#995512
05/19/11 04:21 PM
05/19/11 04:21 PM
RapidRobert
Permatex #3 brush on, on a gasket
