Re: PRO SYSTEMS 1000 HP (4150 CARB)
[Re: Labratt]
#993387
05/16/11 06:37 AM
05/16/11 06:37 AM
Posts: 214 canada,NB
jb15
canada,NB
Patrick built one for Me,ran 9.20s in a sb 408,they have metering blocks set up like a Dominator,ran it for 3 years before moving up to a 110mm SV1,ran great for Me,hard to cast judgement on a carb built for someone elses program.jetting probly required maybe. Jim...
[Re: jb15]
#993388
05/16/11 08:44 AM
05/16/11 08:44 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
I have one of Patrick's 1000HP's, First on my ~600HP 508 and now on my ~700HP 517, I'm VERY HAPPY with my choice. This carb will likely be seeing double duty on my new 414" small block, at least for the short term! 7:1 , Better clean off those plugs, buddy!!
[Re: Labratt]
#993389
05/16/11 10:00 AM
05/16/11 10:00 AM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
i had one of patricks 1000hp's on my 408,ran real good with a best of 10.60@127. on the same day i switched to by Bigs 950 stage 5 plus and ran two back to back 10.55@128's, so my 408 liked the 950 better. same 60's (1.59) with either carb. this was on pump gas and 3350#.
[Re: Labratt]
#993394
05/16/11 06:58 PM
05/16/11 06:58 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Randy, Patrick does great carbs. i did back to back one of his 1000hp carbs against my BG 825 on my satellite.there was like only 0.0001 difference - essentially nothing. i also tried a ultra HP950 later,different meeting against the BG and lost 3/10 and 3MPH. this is on a 0.055 over 440. your result may vary Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Labratt]
#993397
05/16/11 10:16 PM
05/16/11 10:16 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
You get a dyno sheet with every one of Patrick's carbs. There is also a number on the carb, so if you call tech they can help you get it right. And Patrick answers the phone alot of times. Chris..
[Re: tex013]
#993400
05/17/11 10:49 AM
05/17/11 10:49 AM
Posts: 610 long time lurker, short time p...
PorkyPig
So "Patrick does great carbs" but a smaller BG ran exactly the same as a bigger ProSystems?
[Re: PorkyPig]
#993406
05/17/11 06:58 PM
05/17/11 06:58 PM
tex013
Sydney,Australia
Porkypig, i'll expand .a couple of mates run prosystems carbs and they run great. i borrowed my mates unused one,set up for 410ci sb,and it didn't help my motor.i contacted Patrick prior to using it and he suggested it may be a lttle too big.my take on this is the carb size on my motor is not a restriction. i tried the various carbs because when looking to step up my program,some carb shops suggested a 950hp type carb. the prosystems carb felt great and had good responce no mistake,just no improvement over the BG on my package in its current form. as people say - your results may vary
Tex
[Re: tex013]
#993407
05/17/11 07:49 PM
05/17/11 07:49 PM
Streetwize
Weddington, N.C.
Tex, I agree, sometimes 'big enough' is just better and going bigger just kills more initial torque without enough motor to pay you back in HP...seen it a hundred times.
GENERALLY....On a heavier vehicle, I find a slightly undersized carb is better and more consistent than an oversized carb, it's also more responsive to tuning for conditions.
[Re: PorkyPig]
#993408
05/17/11 07:49 PM
05/17/11 07:49 PM
Chris'sBarracuda
Arizona
Ive NEVER seen a ProSystems come with a DYNO sheet, but they do come with a SPEC sheet and suggestions for jetting ranges.
WHATEVER..
You get a F!@#$@@ sheet.... Who cares what it's called..
Chris..
[Re: Labratt]
#993413
05/17/11 11:59 PM
05/17/11 11:59 PM
tex013
Sydney,Australia
Fosters ?! you feeling like puking ? noone in Aus drinks that swill
Tex
