Re: PRO SYSTEMS 1000 HP (4150 CARB)
[Re: PorkyPig]
#993406
05/17/11 06:58 PM
05/17/11 06:58 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
Porkypig, i'll expand .a couple of mates run prosystems carbs and they run great. i borrowed my mates unused one,set up for 410ci sb,and it didn't help my motor.i contacted Patrick prior to using it and he suggested it may be a lttle too big.my take on this is the carb size on my motor is not a restriction. i tried the various carbs because when looking to step up my program,some carb shops suggested a 950hp type carb. the prosystems carb felt great and had good responce no mistake,just no improvement over the BG on my package in its current form. as people say - your results may vary
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#993407
05/17/11 07:49 PM
05/17/11 07:49 PM
Posts: 9,881 Weddington, N.C.
Streetwize
Weddington, N.C.
Tex, I agree, sometimes 'big enough' is just better and going bigger just kills more initial torque without enough motor to pay you back in HP...seen it a hundred times.
GENERALLY....On a heavier vehicle, I find a slightly undersized carb is better and more consistent than an oversized carb, it's also more responsive to tuning for conditions.
[Re: PorkyPig]
#993408
05/17/11 07:49 PM
05/17/11 07:49 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
You get a dyno sheet with every one of Patrick's carbs.
Ive NEVER seen a ProSystems come with a DYNO sheet, but they do come with a SPEC sheet and suggestions for jetting ranges.
WHATEVER..
You get a F!@#$@@ sheet.... Who cares what it's called..
Chris..
[Re: Labratt]
#993413
05/17/11 11:59 PM
05/17/11 11:59 PM
tex013
Sydney,Australia
Fosters ?! you feeling like puking ? noone in Aus drinks that swill
Tex
