PRO SYSTEMS 1000 HP (4150 CARB) #993386
05/16/11 01:48 AM
05/16/11 01:48 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Please state your opinions on this carb! When I was getting my GTX dyno-tuned at Jake's Automotive last year, around this time,we tried one off of Len's '63' Plymouth race engine...for S&G's With a WAY RICH A/F ratio of 7:1..it equaled the best horsepower output of the modified 850 Holley that I was running! I would imagine if it was set-up for my engine..and the A/F ratio was a "friendlier" 12:1 or so..the power output would have increased by a good margin! What do you guys think? Thanks in advance!
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: Labratt] #993387
05/16/11 06:37 AM
05/16/11 06:37 AM
canada,NB
jb15 Offline
jb15  Offline
canada,NB
Patrick built one for Me,ran 9.20s in a sb 408,they have metering blocks set up like a Dominator,ran it for 3 years before moving up to a 110mm SV1,ran great for Me,hard to cast judgement on a carb built for someone elses program.jetting probly required maybe.
Jim...
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: jb15] #993388
05/16/11 08:44 AM
05/16/11 08:44 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I have one of Patrick's 1000HP's, First on my ~600HP 508 and now on my ~700HP 517, I'm VERY HAPPY with my choice. This carb will likely be seeing double duty on my new 414" small block, at least for the short term!
7:1 , Better clean off those plugs, buddy!!
WIZE
In Car:
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: Labratt] #993389
05/16/11 10:00 AM
05/16/11 10:00 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i had one of patricks 1000hp's on my 408,ran real good with a best of 10.60@127. on the same day i switched to by Bigs 950 stage 5 plus and ran two back to back 10.55@128's, so my 408 liked the 950 better. same 60's (1.59) with either carb. this was on pump gas and 3350#.
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: mopar dave] #993390
05/16/11 11:01 AM
05/16/11 11:01 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Guys! Does anyone know what these carbs ACTUALLY flow? I know the 950's supposedly ONLY flow 860-880cfm!
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: Labratt] #993391
05/16/11 11:23 AM
05/16/11 11:23 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We sent Patrick our Holley 950 HP and he worked it over and got it to flow 1040cfm. We have had great luck with the carb but have nothing to compare it to as at the time we changed a few other parts that also increased our hp output. It is very consistent and has pushed the Duster to a best et of 9.46 and a best mph of 144!
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: cl440] #993392
05/16/11 03:33 PM
05/16/11 03:33 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
my 1000hp flowed 982 according to patrick.
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: mopar dave] #993393
05/16/11 05:50 PM
05/16/11 05:50 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thank You for the info,Dave!
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: Labratt] #993394
05/16/11 06:58 PM
05/16/11 06:58 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Randy,
Patrick does great carbs.
i did back to back one of his 1000hp carbs against my BG 825 on my satellite.there was like only 0.0001 difference - essentially nothing.
i also tried a ultra HP950 later,different meeting against the BG and lost 3/10 and 3MPH.
this is on a 0.055 over 440.
your result may vary
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: tex013] #993395
05/16/11 07:19 PM
05/16/11 07:19 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
He did the carb on the Belvedere,,,,,
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: 69CHARGERMD] #993396
05/16/11 09:29 PM
05/16/11 09:29 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Dougie..what carb are you running? Isn't it a 1050 Dominator? Sounds like a LOT of people recommend Patrick..and his carbs!
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: Labratt] #993397
05/16/11 10:16 PM
05/16/11 10:16 PM
Arizona
Chris'sBarracuda Offline
Arizona
You get a dyno sheet with every one of Patrick's carbs.
There is also a number on the carb, so if you call tech they can help you get it right.
And Patrick answers the phone alot of times.
Chris..
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: Chris'sBarracuda] #993398
05/16/11 11:03 PM
05/16/11 11:03 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for the info,Chris! I'm REALLY leaning toward getting one of his 1000HP's in the future! I still have a lot more research to do,though! BTW..LOVE the graphics on your Barracuda!
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: Chris'sBarracuda] #993399
05/17/11 10:47 AM
05/17/11 10:47 AM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Ive NEVER seen a ProSystems come with a DYNO sheet, but they do come with a SPEC sheet and suggestions for jetting ranges.
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: tex013] #993400
05/17/11 10:49 AM
05/17/11 10:49 AM
P
PorkyPig Offline
PorkyPig  Offline
P
So "Patrick does great carbs" but a smaller BG ran exactly the same as a bigger ProSystems?
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: PorkyPig] #993401
05/17/11 11:18 AM
05/17/11 11:18 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Porky..I was scratching my head..and wondering the same thing!!! Does that fact make the BG 825 a "superior" carburetor???
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: Labratt] #993402
05/17/11 12:28 PM
05/17/11 12:28 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Randy, Patrick is a straight up stand up guy and very good at what he does.
Alot of the fast cars run them. If they were junk they would not run them. NASCAR, NHRA Pro-Stock, Pro-Mod's, 10.5 cars on N2O, tractor pulling, boats all run his carbs.
that in itself should tell you how good they are.
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: Labratt] #993403
05/17/11 01:09 PM
05/17/11 01:09 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
IIRC, my Pro System's 950 flows 967 CFM on my bench. (dry)
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: mopartony] #993404
05/17/11 01:12 PM
05/17/11 01:12 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i have one of prosystems E85 dominators,havent tried it yet,but i bought it knowing that stockholms and probably swedens fastest streetcar has one and it was very close out of the box.
Re: PRO SYSTEMS 1000 HP (4150 CARB) [Re: 1Fast340] #993405
05/17/11 06:39 PM
05/17/11 06:39 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
well i hope its better then the sv1 that i saw lose 2mph and 2 10th's on barry's nasty challenger
